LinkInstance location
I cannot seem to find a way to locate a revit link instance in my project. I need to know their placement point like they are a family. Thank you
try get project location from genius loci
I need the location of the link in my host model. Project has no shared coordinates at the moment, this node just returns zero.
try like this
allright try witt clockwork location + and probably a flatten,but guees it will give 0.0 if site origin
Yes, this node works perfectly with walls and other 3D elements but I need the location of the origin.
This will not work, bimorph nodes are proprietary.
I’m looking for any alternative solution, the screenshot was an example. The bimorph node is not able to handle basepoints and origins for some reason
thats why i suggest clockwork
What I meant in proprietary is that you cannot connect clockwork to the bimorph it will return nulls and zeroes. Tried it
should work fine…but probably a flatten as mention…
Its all zeroes as I mentioned
yes your origin is 0.0
Ok maybe I was not clear.
As you see in the screenshot above I have 3 link instances. They are positioned somewhere in my host model. I need the location of the origins. Not the location of the origin in the link but the location of the origin in the host model where I have linked it.
This is why I used the bimorph nodes as they are able to give you the location in the host model, but not working for origins apparently.
try total transform …if i understand
this works. Thank you
