Link/amend autocad layers in revit
I am wondering if there is a way to use dynamo to link autocad xrefs into plan views in revit? Further to this (or as a seperate issue) can you modify the autocad layers (such as the lineweight and colour in revit) using Dynamo? Currently we draw reinforcement as an autocad xref (dont ask why - long story) and link it into revit, but then have to spend quite a bit of time changing the linked CAD’s lineweights and colours within revit to make it look presentable - but it would be great if we could get Dynamo to do this for us.
Hi @gazza23,
You will find in the BimorphNodes and Genius Loci packages the appropriates nodes.
Thanks. I’m still kind of new to Dynamo, so i’m not sure exactly how i specify which DWG i need to link in to which plan view.
Here are a few examples to select views and filepaths.
Link%20DWG
Please mark the topic as solved.
I advise you to read the Primer to understand how Dynamo works.
https://primer.dynamobim.org/
