I’m looking to bring Autocad details into my Revit drawing as drafting views. Doing so means that I will need to link the CAD then go into every detail within Revit and change the Autocad lines to the Revit lines so they have the correct line weights. Is there a way that dynamo can pick autocad layers, colors, line weights, etc. and change them to a line within Revit? Otherwise I’m going into each detail and selecting line chains and changing their line styles to the correct lines.
Hello @Paul.GallioneYRHTV and welcome …something here could be a start…
@sovitek Thank you for your reply. so far this is what i have. I keep getting null (-1) in the list.firstindexof node and basically saying index is out of range. there are 69 lines. Start index is at 0. when i change the count from 1 to 69, the whole list is null in the “total list of lines its styles in the project/string.remove” node
What package has the element classes?
Hi its a ootb node from 2023 instead of “element type” and “all element of type” so if you are in lower version just use them
HI. i am using an older version and im unable to connect all elements of type to a code block. Is there another alternate node?
not sure i understand could you show an image
You could use get at index or type in “a[number of index you wanna use];” in a codeblock
i figured it out…user error. I didnt type in “A” in the begining of the code. thank you for your help.
one more question, how do I tell what graphic style is associated with its line style? thanks for the insight.
you are a master! haha thank you!
Can I see the script you created? I think I have a problem inserting MEP symbols/legends into Revit, and I want to modify them in Revit. I think you’ve already done that.
Hello @rathriftshopp and welcome in the forum
not sure what you have problems with, but create a new topic, share all you have tried so far, include, cad, rvt etc…and the community can try help…welcome ![]()
I have created a new topic. Thank you for your advice. I hope you can help me with the new topic I created.
yeah sure if i can, i will first be in dynamo next week, so lets hope someone can help you before that
good luck
Here is the link to the topic. Thank you. I am very happy that someone can help me. I wish you continued success.
Thank you for making this easy!
