Layer transfer
Hi everyone,
Is there a script for transfering all basic C3d layers to my custom ones?
Thanks, Ivo
You could have a look at the LAYTRANS command in Civil 3D. A layer mapping can be saved and loaded.
If you want to use Dynamo, you probably need to check if a new layer exists, if it contains data, if you need to merge or just rename. Quite complex while the existing function might be good enough.
