Good morning all,
I have a query of which I have no doubt has a very simple answer. I’ve created a dynamo file that inputs strings into parameters on Titlesheets. It functions perfectly fine on an individual basis.
However, when I try to create lists (That do correspond) I can’t take their outputs and directly input them into Element.SetParameterByName.
I’m assuming either my lacing is incorrect (Cross-Product on the Element.SetParameterByName node just inputs the last string into every field though) or I need to change the data format somehow (Arrays vs. String lists etc).
The first node below is individual and works fine. The second is where I have got to so far with my Lists - but it doesn’t work as of yet.
I’m still a bit ‘fresh’ to both Dynamo and Coding so any help would be much appreciated!!
