Hey all, just picked up Dynamo a couple days ago, been doing a lot of reading and finally got my first useful script up and running. Happy with how it turned out, but wanted to post a screenshot of the final version so that some expert eyes could maybe let me know if there’s anything I could do better/ should really avoid doing. Any advice is appreciated!
Nice first graph!
Might want to switch the hard coded names for a family type dropdown, allowing you to do similar for say copper pipe. More use is better than less after all. ![]()
Oh right! Because I can set them as a dropdown input to show up in the dynamo player. That a great suggestion, thanks. ![]()
The way I laid this out is hard coded to address one particular fix we end up having to make a lot, is it possible to set the default selection for those dropdowns to the selections for this particular fix? Or will the dropdown always require a user to select each field correctly? (I work with some individuals where the fewer steps, the better haha)
It should serialize the selection after you make it, with the value requiring a new selection if you are in a file which doesn’t have the selected item in it.
Phenomenal. Thanks for the pointers Jacob!
