I have a question that im sure some one here can answer. I have 2 lists currently and i need to iterate over the first list but then pass the second list into that. So, select first item in list 1 than iterate over list 2’s first sublist, select list 1 second item and iterate through list 2’s second sublist. Image below
I hope i explained it clearly.
I am guessing you have 2 sublists and really what you’re asking is how can you perform cross product lacing with sublist 1 against sublist 2?
Try this (this only works on a list with two sublists; if you are trying to match each item from sublist 1 with all items with sublist 2, then match each item from sublist 2 with all items from sublist 3…etc then this wont work and you should think about how to manage your data better)
dataEnteringNode = IN
list = IN[0]
concat = []
for i in range( len(list[0]) ):
sub = []
for j in list[1]:
sub.Add(str(i)+j);
concat.Add(sub)
OUT = concat
Your intent is still not clear to me.
Maybe @Thomas_Mahon’s cross product suggestion is all that you require.
Thanks for all the responses but i must work on giving you guys a better explanation of what i’m looking for. I ended up figuring out what i needed. I had different size list so i just made them all the same size and then after i removed what i didn’t need. Again thanks for all the help!
@nathan.chapman Would you mind posting the problem and your solution.
Curious as to what the issue actually was.
Vikram-
Below is the image of the custom node i came up with.
So the problem is that each group Index could have a different length of numbers associated with them. So what i did was just look at the groups and find the longest list and input that into the others. Within python it would throw an exception so i would just have it write something at that index to everything stays lined up. Then i chopped the list up. I hope that helps explain.
Thanks, but it would be better to see the list/s that you started with and the result that was obtained.
That might help understand what you were trying to do.
