Evening,
First post!
I am working on a project in Revit where some elements will be wooden poles or ‘sticks’ for lack of a better word. I’m having some success modifying the radius parameter values at random but I cannot seem to get the instances to rotate at their origin points, around the Z axis. I am continually receiving this error:
“Warning: No function called SetRotation on a Revit.Elements.AdaptiveComponent that takes __array,double could be found” for the rotation parameter.
What might be causing this and what would be the best way to randomize the rotation of each instance, regarless of its orientation (i.e. if its not vertical or horizontal)?
Here is the image of where I am getting stuck and of the model objects. I’m using generic adaptive models for the family so that I can place the component easily in the massing environment. There was a python script posted here but no luck figuring out how to make it work.
Any ideas or help are most appreciated, cheers.
