When I place my 4 pts family in Mass pattern by Nodes, the family is working well.
I want some random pattern and I use Lunchbox Panel Quad Random node to create some random pattern. However, after placing family by dynamo, the glass in the family is coming out.
You need to consider the reduction of mullions in your 4point adaptive family. Using curtainwall tools in revit, it automatically reduces the area of your panel.
Thank you for your reply.
I solved the issue.
The reason of the mullions are not behave as I want is the selection of Orient in the family.
When I change to Global (xyz), it works well.
