Hi, I have some issues when using Dynamo Player in Revit 2019. I think the problem might be the Dynamo version used when creating the graphs (v 2.0.3). If dynamo player is use to run a graph before opening Dynamo the graph crashes, but after opening the latest version of Dynamo with the graph, not running the graph, closing Dynamo and then executing the graph with Dynamo Player, everything works just fine.
Any idea if the version 1.3.3 can be uninstall and only use the latest version?
Yes - just uninstall Dynamo 1.3 and/or the associated Dynamo for Revit build via add/remove programs.
