I’m trying to use the Dynamo Player with Dynamo 2.0 in Revit 2017, but after selecting version 2.0, the dynamo player is no longer available.
See Screencast below
https://autode.sk/2qWILTM
Just to be clear, the DynamoPlayer works well if I select Version 1.3.3. BUT it will hang if I select a script thats been saved in version 2.0, since the versions are not compatible.
I’m using the latest version of Revit 2017,
Things I have tried:
Completely uninstall all versions of Dynamo then, Re-install version 2.0
Completely uninstall all versions of Dynamo then, Re-install Dynamo 1.3.3 then version 2.0
Is there specific options that need to be selected when installing Dynamo 2.0 to enable the player in Revit 2017?
Thanks,
