I’m having an issue running a graph to create sheets where the sheets create correctly, but if I change the variables (sheet name / number) and run it again, the sheets I created previously disappear (get renamed?) and I’m totally stumped as to why. Even after closing Dynamo & Revit and running the graph again the same behavior persists and I have no clue what is causing the issue or how to avoid it. I tried putting a transaction start & end in the graph and that didn’t really do much. Oddly, if I use Dynamo Player it seems to work, although it pops a warning every time.
Revit 2018.2
Dynamo 1.3.2.2480
