Dear devoted Dynamo and Revit users,
I have been working on door families which have nested panel families.
As swapping nested families in host component families, which are determined as “Family Type Parameter”, is a bit hassle in the schedule, if it is possible to retrieve element id in the host family and set the element id into the other host families can be very useful.
Is there any way that I can do this??
I tried basic nodes to set the value of parameter but the value for “Family Type Parameter” is not integer nor string but id the nodes didn’t work well.
Is it even possible to set nested family type into a host family with Dynamo?
It would be appreciated if you share your insight with me.
Thank you,
Yuki
