hi everyone,
When The pipe diameters are below 75mm, code is not showing clash points. it gives (x=0, y=0, z=0)
works well when diameter is above 75mm.
clash points.dyn (30.4 KB)
Project2022.rvt (5.3 MB)
LINK FLOOR.rvt (1.4 MB)
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
#The inputs to this node will be stored as a list in the IN variable.
#dataEnteringNode = IN
clashElementsAdirty=IN[0]
clashElementsBdirty=IN[1]
# Start Transaction
clashElementsA = []
clashElementsB = []
clashGeomA = []
FailuresA = []
clashGeomB = []
FailuresB = []
clashFoundA = []
clashFoundB = []
clashSolids = []
clashPoints = []
for a in clashElementsAdirty:
try:
clashGeomA.append(a.Geometry()[0])
clashElementsA.append(a)
except:
FailuresA.append(a)
for b in clashElementsBdirty:
try:
clashGeomB.append(b.Geometry()[0])
clashElementsB.append(b)
except:
FailuresB.append(b)
counterA = range(len(clashElementsA))
counterB = range(len(clashElementsB))
for i in counterA:
tempGeomA = clashGeomA[i]
for j in counterB:
# tempGeomB = clashGeomB[j]
# clashIntersectResults.append(tempGeomB.DoesIntersect(tempGeomA))
# if tempGeomA.DoesIntersect(tempGeomB):
if clashGeomA[i].DoesIntersect(clashGeomB[j]) == True:
# clashIntersectResults.append(clashGeomA[i].DoesIntersect(clashGeomB[j]))
clashFoundA.append(clashElementsA[i])
clashFoundB.append(clashElementsB[j])
tempSolid = clashGeomA[i].Intersect(clashGeomB[j])
clashSolids.append(tempSolid[0])
clashPoints.append(tempSolid[0].Centroid())
# End Transaction
#if fileversion == "":
# OUT="Default settings used"
#else:
# OUT=total_export
OUT = clashFoundA, clashFoundB, clashSolids, clashPoints, FailuresA, FailuresB
