Previous employees put this together so I’m not sure how to fix it. From what I understood, it doesn’t like having the same names… so probably the var…: that it doesn’t like. How can it be written otherwise?
The three directory paths and folder names always change according to the date and selected folder.
The name is what comes first, Directory Path and Folder Name in your case. The variable name cannot include anything that is already a reserved object (the colored words). Easiest thing to do is replace the space with an underscore or shorten the name to something else.
My issue with the nodes not working in different dynamo versions came down to another package was loading a instance before it was being called or installed by the package I was using. So I uninstalled the package(was just a temp install) and my node worked correctly after that.
