Input for transform copyfromviewtoview
Hi, could anyone please tell me what the input for transform is on this node?
Had a look through the dyf on my phone, looks like it might be an Autodesk.Revit.DB.XYZ but will look on the PC tmw :wink:
Could be another error, what happens if you take the code out of the node and deconstruct to remove any error handling…
Looks like it is expecting a Coordinate System to convert to an Autodesk.Revit.DB.Transform (consisting of XYZ Basis and Origin data)
There may be another error in there stopping your views from being copied…
awesome. Thank you. Just figuring out how to get the element origin to get the coordinate system. Transferring area boundaries, then areas and tags
hmmm not this node. Can a model curve have an origin though? :thinking: Do you need the point half way along maybe
I’m not sure, works when I dont try transform it
Tried this but the lines came through all whacko
Your other method did better but some of the lines are odd. Not sure if its a issue with what lines are in what view. Looked all good in the dynamo preview
hmmm
inside the node
thank god
:laughing: Hopefully it will be all worth the struggle in the end :+1:
