Have linked all my details in to drafting in Revit already just want to pick all the lines to create detail lines
Using the layer and co-ordinates XYZ etc for autocad
Cheers guys
Cheers guys
That’s a big ‘just’.
Look into Bimorph Nodes as a starting point which can read CAD lines by layer name from a CAD object. You can then make detail curves from these using dynamo.
Go attempt a script and share your issues from there to get more help from the forums.
Model curves aren’t valid in drafting views, set that to false and use the OOTB node to create detail curves afterwards instead.
Hi there,
I’m quite new to dynamo. did someone figure out this script? could that be shared here?
many thanks,
Claudia
Are you looking to start from scratch and create a drafting view from a dwg or have you gotten to the point of the issue that nathan was having and can’t get past that?
I got to the same point as Nathan and couldn’t fix it. After reviewing with a colleague, we got sorted ![]()
Can you share? kinda went off the project for abit.
Have you solved the problem? I haven’t solved it yet. Can you give me a screenshot of the script?
