hi @markochan2000
you can creat Custom node or using python script.
hello
code block
def XYvector1(x)
XYvect=Autodesk.Geometry.Line.Direction(x);
Xvect = Autodesk.Geometry.Vector.X(XYvect);
Yvect = Autodesk.Geometry.Vector.Y(XYvect);
Compaire= Xvect ==0 || Yvect ==0?x:null;
NCompaire= Xvect !=0 && Yvect !=0?x:null;
return {"parallel":Compaire,"Not parallel":NCompaire};
Cordially
christian.stan
Hi Sam.
I think I almost got it. Thanks to a post by @ Vikram_Subbaiah in Filter by Bool Mask - #5 by Batman86
Take a look.
The only challenges I have now are
to clean the Empty list
Arrange / Flatten the list in the format
Get Back and pick the actual line rather than the vector from the boolean mask.
I would like to accomplish all these within the function.
Thanks in advance
Hello @markochan2000
I was working for your function after adding flatten and clean function to the design script I did not find a way to pick the actual lines because they are outside of the function so for now this script can only take the vectors because they are inside the function,
i add two Code Blocks as Secondary Solution to achieve your final result
(Take Parallel Lines , Take Not Parallel Lines)
Sam;
Function:
def XYvect11(x:var…)
Compaire= Xvect || Yvect ==0?false:true;
t3 =(DSCore.List.FilterByBoolMask(XYvect, Compaire));
t4 = DSCore.List.Flatten((Dictionary.ValueAtKey(t3, “in”))@L3,0);
CleanT4 =List.Clean(t4,false);
t5 = DSCore.List.Flatten((Dictionary.ValueAtKey(t3, “out”))@L3,0);
CleanT5 =List.Clean(t5,false);
return [CleanT4,CleanT5,Compaire];
Code Bloc for Parallel Lines:
t4 =List.Clean(Dictionary.ValueAtKey((DSCore.List.FilterByBoolMask(lstLines, Compaire)), “in”),false);
CodeBlock For Not Parallel Lines:
t4 =List.Clean(Dictionary.ValueAtKey((DSCore.List.FilterByBoolMask(lstLines, Compaire)), “out”),false);
Thanks a lot. I will try further fromm here.
@markochan2000
you welcome .
