Input in Imperative Function
Hi Fam,
Why is it that an input reads null inside an Imperative Function?
For example:
This would work, with input being driven by any integer manually or by slider.
input;
output = [Imperative]
if (input == 0)
output = “ZERO”;
return output;
Successfully returns “ZERO”
However, once I turn it into a function:
def GOGO(input) // I’ve tired input:var, input:var[], input:int, intput:int[], input, etc…
if (input == 0)
output = “ZERO”;
return output;
GOGO(0) returns null.
Help?
Try initialising your variables :
def GOGO(input:int)
		c = "Nothing to see here";
		if (input == 0)
			c = "ZERO";
		return = c;
	return = output;
Additionally, everytime I restart my dynamo I get an error for that code block saying Variable isn’t defined yet. Seems like a bug. Using the latest version of Dynamo 2.01.5
Hey there thanks for the response but as stated above I already tried all combinations of initializing my variables.
It worked on my version of Dynamo (using 2.01 too).
Without initialization :
2018-07-27%2016_55_06-Dynamo
I tried on another machine and it seems to be working now. Very strange why does a code block behave differently on another machine? Anyways looking at your code, couldn’t it be simpler to do this? Why do you have different return outputs and two ending semicolons?
I have found that sometimes I need to restart Dynamo for my imperative blocks to execute correctly. It seems that after being executed a few times they get tired and need a restart :slight_smile:
Hi All ! I have the same issue here and can’t reach a solution. Any help is needed :slight_smile:
i always get ‘1’ no matter what the input was .
