Hi!
I’m trying to make a variable from the length of a curve to use it in some design script later in the graph.
I read some other post and it seems that this is not possible?
if it is not possible do you have any suggestions?
Thanks!
Hi!
Thanks!
Hi!
I think it should work if you just set the Code Block as “x”, whithout involving a function L().
Great! it’s gonna put a couple additional crossing wires in my graph but not a bad solution!
Thanks!
An alternative would be to do the same as suggested in this thread. However, I would stick to the easy fix if your graph is not too complicated
