Impossible to print PDF
Im trying to print several PDFs from dynamo all works just fine but there is no PDF at the end…
Can somebody help me please???
Hi @DBESSON-CCA,
It’s difficult to help you without seeing any previews under the nodes.
Multiple causes can explain the failure. An error in your graph, a bad configuration of PDFCreator …
I suggest you disconnect the user interface part (data-shapes) to focus on the printing part first.
When everything is working, you can then reconnect the interface part.
I had a problem with the format in Adobe PDF, I failed to use your Node, I had to use the archi-labs one …
But now everything is going well
thank you very much for giving me an answer !!
