When we generate geometry in Dynamo - via curve.extrude - and and then import instances via “import geometry”, that results in a “symbol” in Revit, that if exploded, results in “nothing”.
If partially/complete exploded, we get this “Import contained 3D data or points which can’t be exploded. Only 2D data was exploded.”
What is the way of importing the extruded geometry and keep its flexibility (parametrization) after we transfer that to Revit? - as main point of Revit/BIM is
parametrization and intelligence embedded in entities.
Thanks for suggestions/comments.
