Import Room Name to Revit
I have a series of nodes, which extract the room labels, then divide them by floors, and then by areas, then the room names are placed both in front and behind some texts, the problem is when importing into Revit the data, Revit freezes.
I hope the image with the nodes can help
Hi @sinopsis19 ,
Could you retake your screenshot using the built-in camera tool (after zooming in to make it high-res)? I can’t really read the node names. Sharing this Dynamo file and perhaps a Revit (sample) file would also help tremendously.
Are you READING the room name then REWRITING it in the same go?
