Hi Gents
Are There any code about Importing Navisworks viewpoints as XML to REVIT views
thanks in advance
Nurullah
Hi Gents
thanks in advance
Nurullah
Hi @NURULLAH_KEMAL ,
you can set the vieworientation of a view3d (not an axonometric though). You’ll need to provide the eyeposition,upDirection and forwarddirection:
If you can export that from nwc then it should be possible
automaticly i wanna use this viewpoints as sectionbox view
i wanna create sectionboxe with dynamo by using NWC viewpoint
anyway thanks for this code i will try thanks
