How to export To NWC files using Dynamo
How to Export NWC from 3D View for all list of Opened Files in Revit Using Dynamo
Exporting One by One is bit Problem, Howover we can export all opened files to IFC in a single click but whereas is the bit Problem!, Kindly give the solution to resolve!
Thank you…
Hi @amarkonathala maybe try the great Genius Loci package, there is a node for that.
Cheers
Hi @paris installed but How to get the list of views in Opened Revit Files
The search function is an useful tool :
Hi @Alban_de_Chasteigner
Thanks for the Post
Getting error with the custom node from Genius loci package!
I am using revit 2020 Dynamo version
How to get solve it
The Document Properties node was probably updated since february.
Replace this node with the updated version using the search function in the Dynamo library.
Updating your Revit 2020 to the latest may also help - will give you the updates all the way to 2.3 if I am not mistaken.
  1. Select the Revit menu.
  2. Select the ‘Export’ tab.
  3. Choose the NWC format.
  4. Click the ‘Navisworks Settings’ button at the bottom of the window.
  5. Expand the ‘File Reader’ submenu.
  6. Find and set the Coordinates field to ‘Shared.’
  7. Import your NWC file into Navisworks, and your model should now be properly positioned geographically.
  8. If you want to federate many NWCs in an NWF file, you can simply use the ‘Append’ function in Navisworks and open your files simultaneously.
  9. Once this is done and all the NWCs appear in your Selection Tree, you can go ahead and ‘save as’ your Navisworks project as an NWF.
Or you can use Dynamo Revit to reduce the time needed to create an NWC.
[Blatant advertisement attempt removed by moderator - please do not revive old threads only to promote a video]
