I want to create my own .csv reader
path = IN[0]
z=[]
with open(path) as csv_file:
csv_reader = csv_file.readlines()
for row in csv_reader:
z.append(row.strip())
OUT = z
i get my data but i can`t acces it. Why?
should i change .csv file format. f.e. i want access different sheetnames Data1/Data2/Data3/…
Try using a string node for the ; separator, instead of a code block.
Try this, works on my end. Edit: in fact I made a custom node for it in Crumple (on github, will be in a future version).
# Made by Gavin Crump
# Free for use
# BIM Guru, www.bimguru.com.au
# Boilerplate text
import csv
import os
# Preparing input from dynamo to revit
csvPath = IN[0]
# Try to read the file
if os.path.isfile(csvPath):
with open(csvPath,"r") as file:
reader = csv.reader(file,delimiter = ",")
csv_data = list(reader)
result = "CSV contents read."
csv_data = []
result = "CSV contents not able to be read."
# Preparing output to Dynamo
OUT = [csv_data,result]
Below is the exporter from Crumple as well if it helps anyone:
# Free for use
# Boilerplate text
import csv
import os
filePath = IN[0]
data = IN[1]
deLimit = IN[2]
append = IN[3]
# Determine writemode
if append:
writeMode = "a"
modeName = "appended"
writeMode = "w"
modeName = "written"
# Prepare data rows
csvData = []
try:
for row in data:
dataRow = deLimit.join(row)
csvData.append(dataRow)
doProceed = True
except:
doProceed = False
# Try to write the file
if os.path.isfile(filePath) and doProceed:
try:
with open(filePath, writeMode) as file:
for row in csvData:
file.writelines(row + "\n")
result = "CSV data " + modeName + " to existing file."
except:
result = "CSV file could not be accessed."
elif doProceed:
try:
with open(filePath, "w") as file:
for row in csvData:
result = "CSV data written to new file."
except:
result = "New CSV file could not be created."
result = "Data not writeable as CSV. Check types/formatting"
OUT = [csvData, result]
