Python Error - Dynamo not finding python module
I’m trying to parse a CSV file to write to parameters in Revit.
The data is sort of badly formatted by the program that outputs it, so i’m trying to clean it in python.
The inputs to this node will be stored as a list in the IN variables.
dataEnteringNode = IN
import csv
with open(dataEnteringNode,‘rb’) as f:
reader = csv.reader(f)
li = list(reader)
new=
for ele in li:
if ele[1]==‘Room’:
new.append(ele)
Assign your output to the OUT variable.
OUT = new
When i run the script, i get the following error
File “”, line 3, in
ImportError: No module named csv
the csv module works in the python shell, so how do i tell dynamo to access the csv module?
also, are there code tags that i’m missing?
Hi @OrangeOcelot
You have to add library path.
