solved
Could you share the python code? I’m interested in the curves around windows in walls, is that what you get from that method?
the solution:
bounding = the resulting bounding loop
doc = the active document
element = the wall element
as I used:
openingIds = element.FindInserts(True,True,True,True)
results in a list of all openingIds for each wall.
as the openings are received as ElementIds the elements have to be extracted from the Ids using doc.GetElement(openingId)
orient = the direction of the vector intersecting the wall
the python command:
bounding, orient =I.ExporterIFCUtils.GetInstanceCutoutFromWall(doc, element, doc.GetElement(openingId),)
Thank you, I’m missing a reference or something:
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.IFC import *
wall = UnwrapElement(IN[0])
familyInst = UnwrapElement(IN[1])
vec = IN[2].ToXyz()
OUT = ExporterIFCUtils.GetInstanceCutoutFromWall(doc,wall,familyInst,vec)
ok, thought that was obvious
here the modules:
I = Autodesk.Revit.DB.IFC
It should have been obvious yes, looks like it’s an issue with my revit 2017 install. I got it working in 2016. Thank you very much for your help.
OK I got it working:
I forgot to reference the RevitAPIIFC.dll, and the vector needed to be in a StrongBox container in rvt 2017
clr.AddReference('RevitAPIIFC')
vec = clr.StrongBox[XYZ](wall.Orientation)
#Get curves
curves=ExporterIFCUtils.GetInstanceCutoutFromWall(doc,wall,familyInst,vec)
#Convert to dybmo geometry:
OUT = [curve.ToProtoType(True) for curve in curves]
einar, the strong box container was already required with revit 2016.
actually there are two ways to achieve the strongbox container:
the first solution is the one i suggested.
the strong box container is constructed as a tuple bounding, orient
so the same is achieved as with your suggestion:
Thank you for the explanation Peter. I’m not sure that I completely understand how the StrongBox works, but I’m happy as long as it works.
For anyone that’s interested, here’s the code that returns all opening curves from a wall:
from clr import StrongBox
#Get direction and openings from wall:
vec = StrongBox[XYZ](wall.Orientation)
openingIds = wall.FindInserts(True,True,True,True)
#Get curves and convert to Dynamo geometry:
openingCurves = []
for id in openingIds:
opn = doc.GetElement(id)
curves = ExporterIFCUtils.GetInstanceCutoutFromWall(doc,wall,opn,vec)
openingCurves.append([curve.ToProtoType(True) for curve in curves])
OUT = openingCurves
same for me, i just found out in reading ironpython help, that the strong box in python may be achieved with a tuple for out and in. that is what i did.
using the clr.StrongBox maybe is preferable as more straightforward aligning with the c# coding
cheers
Was STRUGGLING with this - didn’t realize I needed to add RevitAPIIFC reference…thanks for the assist!
