Accesing sketch lines of a wall element
Hi all,
Following what’s been discusse in the following thread:
I’m trying to get the sketch lines of a wall object. I copied the python code posted by @Ben_Osborne but I’m getting an error:
My code is as follows:
# Import RevitAPI
clr.AddReference("RevitAPI")
items = UnwrapElement(IN[0])
elementlist = list()
for item in items:
	trans = Autodesk.Revit.DB.SubTransaction(doc)
	trans.Start()
	ids = doc.Delete(item)
	elementlist.append(ids)
	trans.RollBack()
OUT = items
What did I do wrong?.
Thanks!
You missed a line -
There should be a line that says:
right before the:
for item in items:
Right, my mistake. Now, I’m getting an error as follows:
Looks like you were after some id collector. As an input, I have a list of walls selected in the view. I’m looking for the sketch lines that defines each wall element, do you know how to get them?
Thanks in advance.
# Import RevitAPI
app = uiapp.Application
sketchlines = UnwrapElement(IN[1])
sketchlist = list()
foundidlist = list()
for sketchline in sketchlines:
	skid = sketchline.Id
	sketchlist.append(skid)
for item in items:
	trans.Start()
	ids = doc.Delete(item.Id)
	trans.RollBack()
for i in range(0,len(items)):
	idslist=list()
	idslist = elementlist[i]
	intermediatelist = list()
	elements = list()
	for j in range(0,len(idslist)):
		id=idslist[j]
		for k in range(0,len(sketchlist)):
			sketchid = sketchlist[k]
			if id==sketchid:
				intermediatelist.append(id)
	for m in range(0,len(intermediatelist)):
		el = intermediatelist[m]
		elements.append(doc.GetElement(el).ToDSType(True))
	foundidlist.append(elements)
elements = []
OUT = foundidlist
Nice work @Ben_Osborne, thanks!. Looking into the code, I see that you use as an input the sketch lines (IN[1]). I want to get the sketch lines of the element, not as an input:
Regardless of whether your code works for my problem, it is good to know and I’m sure it will be handy in the next step of my script. Thanks a lot!
I found that Springs package’s Spings.COllector.ElementSketch node do the job.
Thanks!
in the Spings.Collector.ElementSketch (@Dimitar_Venkov) node, why is it returning only the curves from the last wall?
