Curtainwall Perimeter Curve
I’m trying to get the perimeter curves that define a curtain wall, but I can only get my python node to return Autodesk.REVIT.DB.LINE. It seems like I am having trouble wrapping the lines because the lines are non visible objects, but I could also be missing something obvious. Any help is appreciated.
Ultimately I’m trying to automate curtainwall elevations, but this one piece is blocking me.
import sys
import math
#Import Revit Nodes
clr.ImportExtensions(Revit.GeometryReferences)
# Import RevitAPI
clr.AddReference('RevitAPI')
from clr import StrongBox
import System
dataEnteringNode = IN
optA = Options()
optA.ComputeReferences = True
optB = Options()
optB.IncludeNonVisibleObjects = True
curtainWall = UnwrapElement(IN[0])
curtainWallGeometry = curtainWall.get_Geometry(optB)
OUT = curtainWallGeometry
You can use the “.ToProtoType()” method to access the line elements in the curtain wall. I also added an if statement to limit the method to only be run on lines, since the “get_Geometry()” method also retrieves solids from the curtain wall. Hope this helps.
import sys
import math
#Import Revit Nodes
# Import RevitAPI
import System
curtainWallElements = []
optA = Options()
optB = Options()
for item in curtainWallGeometry:
	if item.ToString() == "Autodesk.Revit.DB.Line":
		curtainWallElements.append(item.ToProtoType())
		pass
OUT = curtainWallElements
