Wall type function is "Exterior" with python
Hi all,
I would like to get only exterior wall with a python script.
I did this (see below):
#Import librairies and Namespaces
import System
import math
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitAPIUI’)
#Document and Transaction
from Autodesk.Revit.DB.LabelUtils import GetLabelFor
from Autodesk.Revit.DB.ParameterFilterRuleFactory import CreateEqualsRule
from Autodesk.Revit.DB.ElementId import *
#Define the inputdata
Walls = UnwrapElement(IN[0])
#Creating a variable doc which set the active Revit application and document
#Start the script
#Avoir les murs ayant une fonction du mur
ext=ElementId(BuiltInParameter.FUNCTION_PARAM)
Parameters=ParameterFilterRuleFactory.CreateEqualsRule(ext,(WallFunction.Exterior))
#End the script
OUT=Parameters
It doesn’t work , Dynamo said that : no module named ElementId
Thank you for your help :slight_smile:
Is this what you are trying to achieve?
I don’t want to use str because if my revit are not in english that kind of script doesn’t work.
That’s why, I’m using API.
Yes :slight_smile:
Please mark post as solved.
To clarify, the link and python pointed out by @erfajo also works, regardless of language for anyone other than the initial coder, and has the added benefit of allowing selection of other walls by their type, so I’m putting forth this hybrid of both codes incase it helps someone else find walls of a given function in the future.
