Get IfcGuid, how?
i stuck for any reason… UnwrapElement did not change the result.
clr.AddReference('RevitAPI')
#collector
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls)
all_elements = collector.WhereElementIsNotElementType().ToElements()
walls = [i for i in all_elements if i.Name.Contains("STB")]
out = []
for e in walls:
	BIP = BuiltInParameter.IFC_GUID
	ifcguid = (e.get_Parameter(BIP)).AsString()
	out.append(ifcguid)
OUT = out
grafik
thats any more the solution :frowning:
out = []
for e in UnwrapElement(IN[0]):
	out.append(ifcguid)
OUT = out
KR
Andreas
you can add a conditional statement
#collector
walls = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements()
out = []
for e in walls:
	paraifc = e.get_Parameter(BuiltInParameter.IFC_GUID)
	if paraifc is not None:
		out.append([e, paraifc.AsString()])
OUT = out
@c.poupin ,
it works well
KR
Andreas
