IFC Export - Missing/Empty Properties
Hello guys,
I need to ask you another time for your help:
I have a model with several piles. These piles have the following properties:
This is what I get from the exported ifc:
As you can see the properties of ID-Daten (Identity Data in english) for example are empty.
This is how I set up the propertyset in the export options:
How do I get all properties of a pile exported? For example the group “Bemessungsergebnisse” is completly missing.
Might want to ask this over on the Revit forums - not a Dynamo issue.
@leonard.moelders you can check the Revit IFC Manual:
Got it “solved”.
I opened the ifc-file in an ifc-Viewer and all parameters exist. Revit was the problem, as it did not show these parameters.
