Hi everyone,
I am trying to export IFCs in Revit via Python scripts in Dynamo.
What should I add below for me to export a specific phase.
Thank you in advance.
Hi everyone,
Hi @blsalvio,
The option for the phase is not visible in the Revit API.
https://apidocs.co/apps/revit/2019/666a023b-dad9-4246-079c-1c4e8070bec9.htm
But you can export a given view with its properties. (phase, phase filter…)
You can use the Export IFC
node in Genius Loci package for that purpose.
You’re right.
There is indeed a property when looking in the IFC source code that is not present in the Revit API documentation.
in python :
options.AddOption(“ActivePhase”, str(phase.Id));
-if you want to export ifc from your current opened document you need to use the builtin (select phase) node as an input.
-if you need to export ifc from another Revit document then you will need to collect the phases using (Document.Phases) from Clockworks package
