Actualy, these models are at the same place. I can`manage it with a vector.
So i tried bounding box, how can it work?
KR
Andreas
KR
Andreas
You are on the right path. You can SetParameterByName using your output from GetParameterValueByName.
Will just need some list management to make sure the values assign to the correct project wall.
in addition to the boundingbox, to be sure that it is the right wall, I suggest adding a filter by comparing the locations (curves)
