sorry i just mean show whole graph…with nodes as here
so we can see whats goin on
sure ill do that.
hold up, i think i used the wrong FamilyInstancebyGeomtry node
hmmm thats not the way i show…try do exactly as in post #16 and try with the right family insert node from synthezise…right now you feed in a family instance into your surface
yes seems to work now ![]()
element.faces is giving internal error. i will check why its giving the eroor
yeah difficult to say as your image you upload isnt clear…you need zoom in and have you nodes expanded so we can see whats goin on…you can share you graph and rvt you try on here and i take a look
ok. ill do that. in the meantime, could you share your script which had worked? so that i we can rule out if there is mistake with the script?
I dont have it anymore i just made it for an exemple…
WallProfileSynthesize.dyn (37.0 KB)
aaaaa.rvt (5.4 MB)
files i’m using. the rvt has mass inserted
the rvt you send dont have any walls or room ???..anyway try with crossproduct as here in the intersect node…
WallProfileSynthesize.dyn (44.6 KB)
hello, was assigned some other work. now back to plastering. will checkout the script that you have uploaded.
Hi @10dbim3 not sure as we cant see what goin on…could you share an image with the whole graph with all output showed…thanks
