I try to learn stuff regarding python, is there any usage for “magic methods and attributes” ?
clr.AddReference('RevitAPI')
clr.AddReference('System')
wall = UnwrapElement(IN[0])
nam = IN[1]
def __getattr__(self, name):
return self.AsValueString(name)
OUT = __getattr__(wall,nam)
can i call a name of wall with that? how can i use this kind of magic ?
KR
Andreas
This method __getattr__
will allow you to “catch” references to attributes that don’t exist in your object, and/or it can also be used to generate an attribute dynamically
In all cases the object must be constructed from a Python class, (not Net Class)
however, you can use the getattr()
method to set the default value if the attribute no exist
import sys
pt = Point.ByCoordinates(4,5,0)
# example 1
# try to get 'XY' attribute,
# if attribute no exist return a default value 'None' instead of an error
a = getattr(pt, "XY", None)
# example 2
# try to get 'XYZ' attribute,
# if attribute no exist return each coordinates instead of an error
b = getattr(pt, "XYZ", (pt.X, pt.Y, pt.Z))
OUT = a, b
Hello @c.poupin ,
that means all my elements in Revit are .Net elements?
this kind methods want work on relular categories and instances…
Even when they are expoxed to the UnwrapedElement list…?
KR
Andreas
yes
UnwrapedElement() allows finding the native Revit API objects (that DynamoAPI has wrapped beforehand)
if you want use __getattr__
you need to build your own class
