Get rotate method by FamilyInstance
Hi, friends!!!
I am starting learn Python and I need help. I want get FamilyInstance by rotation method (true or false). What am I doing wrong?
Python3
can you write your code ?
and what is the error you got ?
clr.AddReference(‘RevitAPI’)
import System
clr.AddReference(‘System.Core’)
clr.ImportExtensions(System.Linq)
import math
point = UnwrapElement(IN[0])
rotation =
for i in point:
rotation.append(FamilyInstance.rotate(True))
OUT = rotation
try this
rotation.append(i.rotate())
Thank you so much!
All working!!
that’s Great :slight_smile: ,
please mark it as Solved
