Get linked elements how?
hello,
so i get my links and names but finaly i can`t call the elements… where do i stuck
#Template
#DraxlA
#19.07.2023
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
#uidoc=DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
app = uiapp.Application
#links
all_docs = app.Documents
names = [d.Title for d in all_docs]
link_doc = all_docs(IN[0])
#collector
collector = FilteredElementCollector(link_doc).OfCategory(BuiltInCategory.OST_Walls)
all_walls = collector.WhereElementIsNotElementType().ToElements()
OUT = ,all_walls
i can`t indexing it
KR
Andreas
It looks as if you have a DocumentSet, which is an IEnumerable Revit class, but is not a Python List. Convert the object to a list via a means such as this: allDocs = [d for d in app.Documents]
@jacob.small ,
it works right now !
is there a way to ask the element like “IsLinkedElement” ?
KR
Andreas
Not sure what you mean… but the elements themselves will have a bunch of things you can do with them based on what type of element they are. So best to take one element out of that list and find out what you can do with it.
OUT = dir(all_walls[0])
