How to use generative design in dynamosandbox?
I know how to use it in revit. But how to use generative design in dynamosandbox?
try project refinery
First install Revit with a matching Dynamo build to the sandbox version you are after, then install Generative Design for Revit (both of these are available from the Autodesk Accounts portal).
Once that is done open your Revit, then launch Dynamo to make sure Generative Design shows up there. Next go to your settings in that Dynamo session to see what package paths you are using - one will be in Program Data. Find the Generative Design folder in that path, and copy the folder from there to a matching folder for your Dynamo Sandbox package folder. Relaunch sandbox and you should be all set.
