How to switch Dynamo version while using Revit
Hi there,
once a day Revit asks me to select the Dynamo Version (1.3.3 and 2.0 installed).
Later, this question does not appear anymore.
How can I change the Dynamo version, used by Revit, manually?
My target is to compare the Dynamo version 2.0 (not used yet) to the version 1.3.3 (used until now).
Must i delete some temporary file or deactivate any setting in Revit?
One way is to close revit and reopen it. Then you are asked again when you relaunch revit :slight_smile:
It’s actually that easy, I thought I already tried this … :slight_smile:
Thank you very much
Hello! I have the same issue. I am now running version 2.0 and cannot access the package Sastrugi Package Version 0.1.4 that I just installed. The scripts are not appearing when I set the folder to the directory of where the scripts are. I though it was because of using 2.0 instead of 1.3.3, so I rebooted Revit, but does not give me the option to select the version of Dynamo as it once did after the update.
