As shown in image, highlighted in yellow, distance of offset of section line is 110985160 which i want to set only 200mm from element. Can anyone suggest how to set or fix this distance.
Please note this view is generated through “Tool.assemblyviews”.
what do you already have?
show youre graph
see below
One view is place in sheet properly and other views are not set in sheet, that’s my problem.(Second Image)
far clip must been set to clip
and with the node Element.SetParameterByName you can set the distance and far clipping
Cheers
Section line so far from Element, not far clip problem.
if you are change far clip, then not appear element in view.
