Hello, can you help me to optimize (I need to make the code run faster) the code:
(it selects all elements in the active view by several categories)
clr.AddReference(‘RevitAPI’)
import Autodesk,RevitServices
a=FilteredElementCollector(doc,doc.ActiveView.Id)
b=FilteredElementCollector(doc,doc.ActiveView.Id)
c=FilteredElementCollector(doc,doc.ActiveView.Id)
d=FilteredElementCollector(doc,doc.ActiveView.Id)
rooms = ElementCategoryFilter(BuiltInCategory.OST_Rooms)
walls = ElementCategoryFilter(BuiltInCategory.OST_Walls)
windows= ElementCategoryFilter(BuiltInCategory.OST_Windows)
doors = ElementCategoryFilter(BuiltInCategory.OST_Doors)
rooms=a.WherePasses(rooms).WhereElementIsNotElementType().ToElements()
walls=b.WherePasses(walls).WhereElementIsNotElementType().ToElements()
windows=c.WherePasses(windows).WhereElementIsNotElementType().ToElements()
doors=d.WherePasses(doors).WhereElementIsNotElementType().ToElements()
OUT=rooms, walls, windows, doors
Take a look at The Building Coder site, Jeremy talks a little bit about speed and efficiency in this link that may help.
Efficiency Guidelines
- Filter quick aspects first
- Filter slow aspects later
- Do not use .NET or LINQ until after exhausting the built-in filtering techniques
http://thebuildingcoder.typepad.com/blog/2015/12/quick-slow-and-linq-element-filtering.html
and this page
https://forums.autodesk.com/t5/revit-api-forum/quicker-filtering-by-element-name/td-p/5984705
Not sure how much this will help you, but worth taking a look.
Cheers,
Matt
Why not use the ElementMultiCategoryFilter(). Here’s an example:
# Copyright(c) 2017, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
# Import RevitAPI
clr.AddReference("RevitAPI")
import System
from System import Array
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
try:
errorReport = None
cat_list = [BuiltInCategory.OST_Rooms, BuiltInCategory.OST_Walls, BuiltInCategory.OST_Windows, BuiltInCategory.OST_Doors]
typed_list = List[BuiltInCategory](cat_list)
filter = ElementMulticategoryFilter(typed_list)
output = FilteredElementCollector(doc).WherePasses(filter).ToElements()
except:
# if error occurs anywhere in the process catch it
import traceback
errorReport = traceback.format_exc()
# Assign your output to the OUT variable
if None == errorReport:
OUT = output
OUT = errorReport
Cheers!
@Konrad_K_Sobon, Thank you very much!
to select all items in the active view, i need to replace only one string
output = FilteredElementCollector(**doc,doc.ActiveView.Id**).WherePasses(filter).ToElements()
@til.shviger can you start a new post? This is a new question and it’s unrelated to MultiCategoryFilters.
Cheers!
