Select Elements by Category (error can not get IselectionFilter)
Hi!
How to select elements by category.
I tried but allway return except:
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI.Selection import ISelectionFilter
class Single_Category(Selection.ISelectionFilter):
	def __init__(self, cat):
		self.cat = cat
	def AllowElement(self, e):
		if e.Category.Name == self.cat:
			return True
			return False
	def AllowReference(self, ref, point):
		return true
def selects():
    try:
        picked = uidoc.Selection.PickObjects(Selection.ObjectType.Element, Single_Category('Walls'),"Let Select Model")
        element = [doc.GetElement(i) for i in picked]
    except:
        TaskDialog.Show("Operation canceled","Canceled by the user")
    #return element
clr.AddReference('System.Windows.Forms')
clr.AddReference('System.Drawing')
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
class MainForm(Form):
	def __init__(self):
		self.InitializeComponent()
	def InitializeComponent(self):
		self.label1 = System.Windows.Forms.Label()
		self._button1 = System.Windows.Forms.Button()
		self._textBox1 = System.Windows.Forms.TextBox()
		self.SuspendLayout()
		# label1
		self.label1.AutoSize = True
		self.label1.Location = System.Drawing.Point(15, 30)
		self.label1.Name = "label1"
		self.label1.Size = System.Drawing.Size(65, 25)
		self.label1.TabIndex = 1
		self.label1.Text = "1.A"
		# button1
		self._button1.Location = System.Drawing.Point(260, 230)
		self._button1.Name = "button2"
		self._button1.Size = System.Drawing.Size(75, 25)
		self._button1.TabIndex = 0
		self._button1.Text = "Select"
		self._button1.UseVisualStyleBackColor = True
		self._button1.Click += self.Button1Click
		# textBox1
		self._textBox1.Location = System.Drawing.Point(160, 30)
		self._textBox1.Name = "textBox1"
		self._textBox1.Size = System.Drawing.Size(175, 25)
		self._textBox1.TabIndex = 1
		self._textBox1.Text = "50"
		# MainForm
		self.ClientSize = System.Drawing.Size(360, 270)
		self.Controls.Add(self.label1)
		self.Controls.Add(self._textBox1)
		self.Controls.Add(self._button1)
		self.MaximizeBox = False
		self.MinimizeBox = False
		self.ShowIcon = False
		self.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen
		self.Name = "MainForm"
		self.Text = "SelectByCatagory"
		self.ResumeLayout(False)
		self.PerformLayout()
	def Button1Click(self, sender, e):
		self.selected = selects()
		pass
form = MainForm()
Application.Run(form)
OUT = form.selected
Which version of Revit / Python Engine are you using ?
Hi!
I tested for Revit2022 and Revit2023-IronPython, but not work.
Why don’t you use the node from the Data-Shapes package? Additionally, Data-Shapes has nodes for creating Window Forms in Revit. Check: Blog – data|shapes
Here the code fixed
class Single_Category(ISelectionFilter):
		self.cat = cat
			return True
			return False
		return true
def selects():
	elements = []
	try:
		pickeds = uidoc.Selection.PickObjects(Selection.ObjectType.Element, Single_Category('Murs'),"Let Select Model")
		elements = [doc.GetElement(i) for i in pickeds]
	except:
	return elements
	def __init__(self):
		# label1
		# button1
		# textBox1
		# MainForm
		self.Close()
form = MainForm()
OUT = form.selected
Yes, I know it. But I want control my form.
Thank you !!!
