Hi
I am using dynamo to generate some patterns for alias,
I would like to use this multi surface input from alias and rebuild to single surface by keeping the boundary as it is.
I tried to join as polysurface, its seems not working.
is there any methods to rebuild the surface as single entity ?
May I ask why you need a single surface? Just in case it is for being able to apply a specific pattern, we will have a solution soon to distribute patterns over nearly any kind of multi surface structure.
Thanks for your inputs.
I am in a process to develop a generic script which can be used to convert any 4 sided multi surface entity (like my ref model) to a single surface with same boundary and section.
In this case, can we project curves on this multi-surface in U and V axis (controlled by an integer slider) and rebuild the projected COS as a Nurb curve and build a single surface using guide curves, cross-sections ?
Haha, I was thinking about the exact same approach! Yes, my idea was to first generate the base surface with the 4 outer curves. Then create iso lines on that surface, and then project those lines onto the original surfaces, to then afterwards generate a more precise rebuild with the Loft.
Can’t tell if this would work without trying it. The Curve.PullOntoSurface node would be needed here during the process, I guess.
Could you please supply the script itself? It’s really hard to judge a script by a screenshot, without being able to click on the nodes, makes them visible, see the help, etc.
