VV = UnwrapElement(IN[0])
draftingview1 = DraftingView.ByName(vv)
view1 = Elements.Views.View.SetScale(draftingview1, 1)
pt1 = Autodesk.Point.ByCoordinates(0, 0)
pt2 = Autodesk.Point.ByCoordinates(5000, 0)
line1 = Autodesk.Line.ByStartPointEndPoint(pt1, pt2)
detailcurve1 = DetailCurve.ByCurve(view1, line1)
#detailcurve1 = doc.Create.NewDetailCurve(view1, line1)
OUT = detailcurve1
It is working with Code Block. But it is not working inside the python script
whats your imput?
i see some syntexstuff vv VV, DraftingView is named differently:
use the template from Primier Dynamo Python.
KR
Andreas
@auriffbasha.capital it is not that simple to just “Node to Code” nodes and gets them to work in python,
this will get you started:
clr.AddReference("RevitAPI")
vType = FilteredElementCollector(doc).OfClass(ViewFamilyType).ToElements()
for v in vType:
if v.get_Parameter(BuiltInParameter.SYMBOL_NAME_PARAM).AsString() == "Detail":
vId = v.Id
draftV = ViewDrafting.Create(doc, vId)
p0 = XYZ(0,0,0)
p1 = XYZ(5000,0,0)
curve = Line.CreateBound(p0, p1)
dCurve = doc.Create.NewDetailCurve(draftV, curve)
OUT = dCurve
Thank you,
But I want to place a line in particular Detail View.
@auriffbasha.capital something like this?
P.S.: when you want to mention someone, please use “@” character
vType = FilteredElementCollector(doc).OfClass(ViewDrafting).ToElements()
for v in vType:
if v.Name == IN[0]:
#if v.get_Parameter(BuiltInParameter.SYMBOL_NAME_PARAM).AsString() == "Detail":
#vId = v.Id
draftV = v
#draftV = ViewDrafting.Create(doc, vId)
p0 = XYZ(0,0,0)
p1 = XYZ(5000,0,0)
OUT = dCurve
@Elie.Trad, Its working, Thankyou so much
