Thank you in advance for every input!
Since information about wall layers is often not exported correctly during the IFC export of walls, I would like to read out the containing layers with their layer thicknesses for multi-layer wall types.
The problem is as follows:
I have put together a working workflow for 2 wall types. However, I would now like to automate the query a bit, because it does not make sense (and also is not possible) to create dynamonodes for each element-type, as there are 100+ wall types. First approach:
Are there any nodes in one of the libraries /packages, which are suitable to create “for each” loops or would I have to write this myself with a custom python node?
I would need something like this:
For all wall types get material layers + get material thicknesses and store them in separate lists which are linked to the list of wall types.
Unfortunately I can’t program Python. In Java it would probably boil down to 2 treemaps containing ArrayLists as values, maybe there are already ready-made nodes for such a thing? Approx. in this logic:
Afterwards, I would again use a loop to write all the data to Excel.
Column A - WALL_MATERIALS (keys)
Column B - WALL_MATERIALS (values)
Column C - WALL_THICKNESSES (values)
For row spacing, I would use the (ArrayList.length() - 1) of each key in WALL_MATERIALS to get the number of blank spaces under each key in the Excel. The end result should be a continuous list in this format:
Das dazu erstellte DynamoSkript:
DynamoQueryWalltypeLayer.dyn (91.8 KB)
