Hi guys I am be able to create a cross section placed on the reference line, how ever I can not create a solid using solid.byloft node
Here is the script
Envelop Extrusion2.dyn (181.3 KB)
export-csv.xlsx (24.0 KB)
Static-Dynamic.xlsx (48.6 KB)
Here is the script
because your path is not continuous
Yes, there are a missing points in the reference line. So If I complete the line this script should be able to generate the 3D follow the reference line right?
yes
hello, if you combine your starting profile with your list of copied profiles and then you do a list chop of 2, then you send to the solidbyloft node while managing the depth of the list, it should work perhaps
I’ll try it later in the day
edit: Here is capture
cordially
christian.stan
Hi not really sure probably this exemple could help…if you still wanna have the cap
Thanks Guys I will finish the reference line and let you know how it works.
