How to move a familie to a other point? match Openings
I want to move element based on a linked modelelement (location point)…
the problem is the element that i want to move has is orign not in the center:
test.dyn (92.0 KB)
is it possible to move it via boundingbox?
my input is the elements and the desired points!
# Phython-Standard- und DesignScript-Bibliotheken laden
import sys
Openings = UnwrapElement(IN[0])
positions = UnwrapElement(IN[1]).ToXyz()
OUT = Openings.Location.Move(positions)
is this even possible? i have voids so i can`t extract geometry. but i can make a boundingBox
any ideas
KR
Andreas
or can i work with align? the height value i could also map,but not moving inbewteen the wall
I’d pull the points to be co-planar by matching the Z value the ‘target” to the one of the element to move, and then use that as the new location point.
@jacob.small ,
How do i set the Z value. Can i filter my elements. can i use this node as GroupByKey may elements?
test.rvt (2.6 MB)
link.rvt (2.5 MB)
In the Revit API context via Python, it’d be something like:
sourcePnt = IN[0]
targetPnt = IN[1]
shiftedTargetPnt = XYZ(targetPnt.X, targetPnt.Y, sourcePnt.Z)
@jacob.small,
i think have to place the same families as in the linked file
clr.AddReference('RevitAPI')
clr.AddReference('System')
sourcePnt = IN[0]
targetPnt = IN[1]
OUT = shiftedTargetPnt
it works to get the points… it is not possible to place this hostbased family… so the opinings that are positionated … the families have the centerpoint in the center. The families that i want to place, the origin is on the placing level and the need a host(wall/slap)
The XYZ would need to be converted to a Dynamo point in order to use it in the context of Dynamo.
