How to insert a detail line in the middle of a pipe?
Guys, normally I insert the pipe axis lines manually, is it possible to do this through dynamo? Do you have any tips on where to go next?
for example there is a picture below
Sem tĂ­tulo
Hello @leandro.dias and welcome yes its possible in revit itself under pipe duct categori we have centerline…but offcoarse it could be possible with dynamo, but really dont see why
But here is an example with detail curve
I’ve been doing this manually for 10 years, I really have no words to thank you!
Thanks a lot man!
sorry, but where do I find this node “/w document.activeview” Is it a package?
Yeps :wink: from Spring, but you could just use ootb nodes,
I did everything but it didn’t work, it seems that he is not finding the view and because of this error he does not follow the programming.
Hi are you sure you have ironpython 2,7 package installed ? if you are in 23
I didn’t have this package, sorry I’m a beginner and I’m taking the first steps.
You are welcome ;))
